Ok, here's a little about the system so I can explain the problem
XP2500 on an A7N8X Deluxe
500watt power supply
2 optical drives
1 ATA HD
2 ATA HDs connected to onboard SATA RAID via SATA Adapter
When the computer is running, and I reboot it, it hangs
trying to recognize the two "SATA drives". But while it's doing that, if I
hit the reset button on the case, when it boots that time everything comes up
normally.
Does this sound like my HDs are going bad?
Is it likely a cable, MB, PSU, or other problem...?
Let me also add, that the computer has been running for the past 6 months
without the side panel on. I blew the dust out a month ago, and put it back together
before company came over. According the MBM the temps inside are normal.
thanks for any help
-Jeff
2 optical drives
1 ATA HD
normally.
thanks for any help
-Jeff
