drive storage case
quasimodem
Anyone ever seen a cast that was all 3.5 inch slots, or even the adapters to change 5" into the 3.5" drive bays. I want to redo my file server which currently has 12 drives and they're all ghetto'd out in there.
Any help, suggestions, or links would be a great help.
QM
if you dont need the hotswap capabilites these are much cheaper.
http://www.directron.com/stb3t4e1.html
there are expensive rackmounts that are nothing put hotswaps, or you can get a cheap case that has top to bottom 5 1/2's and fill it up with the cmstacker 4in1's. That is what I am curently doing, though the 40 dollar 8bay case i own is no longer made.
Yes, I knew there we cheaper ones for PATA. Those are better. I just came across the other one first. Ignore the man behind the curtain.
Stacker case hold a boatload of drives with 4-in-3 and 5-in-3 modules. Relocating the power switch opens up that 12th bay to add a 4th module. (Plus it has that second power supply bay.)
