paradoxblue
- Jan 4, 2006
I was trying out a small raid card i had. hoping to simply add more drives. I had no interest in raiding anything really.
So I have a WD 500gb drive with some data on it. so I plug it into the raid card, boot up the computer and the drive comes up as inactive.
the card never had time to format. at least not well. so I know the data is there still. I put it back on a mobo plug and restarted. same issue
The drive waits to be initialized and then of course I must format a new partition
Does anyone know a program I can use to simple reinitialize the original letter to see the data. or recover it?
Thanks
Shawn
Thanks
Shawn
