- Apr 7, 2006
So I have an Adaptec 21610SA in my WHS.. The system drive and a few other on using the onboard and I have added drives as needed to my system using the Adaptec controller.
Well I got home today to find out that a drive had failed...I was like ok but then i opened the Adaptec storage manager software to see what the details were...when I did this it deleted my logical device and the drive disappeared.
I took it out ran a quick diag it was fine smart status was ok so I stuck it back in and the controller sees it just fine but my logical device does not show back up? I had it as a simple volume...but what I cant seem to figure out is that if I create it will it delete the data? I can see the data when I plug it into another computer so i know its there.
What should I do? I had most things duplicated so its not a big deal if it does get lost but id like to avoid that.
