Drive cages, where to get?
  • Thread starter Deleted member 12106
  • Start date
D
Guest
I am looking for some drive cages for a project. Not the hot swap type, not the ones that get mounted inside of a 5.25" drive bay. Typically, the ones that go inside of cases. I have an old full tower case I'd like to mod.
Basically, I am after something like http://cgi.ebay.com/Hard-Drive-Moun...3286.c0.m14&_trkparms=66:4|65:1|39:1|240:1318 Not after anything crazy.
Basically, I want 4 that can hold 5 drives, and I can lay them sideways in my case, in the front, and mount them to the case internally. Ideally, something that could hold 2 80mm fans would be great.
Anyone knows where to get this in the EU? The email address I got last time didn't work, fella didn't reply.
Thanks much.
Well, I decided at buying 3 of those for this project, it would make it expensive...
So....I went to Menards and bought some stuff...
Results of some elbow grease...
Set in the bottom of the case...
The 3.5" bays that I will be taking out tomorrow.
So far, I am at about $25 in misc. parts. With this setup, I can add 18 drives in this configuration, then add in my sata back plane to the 5.25" bay, and get 21 total bays.
What I bought:
8x 3x7" ties
2x 1/8" drillbit.(needs to be slightly larger)
Misc screws
6-32x36" threaded rod. This will be used hopefully to tie each "rack" together and screw through the bottom of the case.
I am going to also mod the front of the case to fit 80mm fans, goal is 2x fans in front of each "rack". Then, I plan to add in a 120mm fan in the back, one rated at 190 CFM. Not too worried about noise, where I am putting it will make it a whisper of air. Here is where it will chill out.
The thing that is going to suck is replacing and adding drives, but, it would have sucked with the $30 brackets.
