That's what I bought and used to drill 2 holes, but it doesn't cut them as cleanly as I would like.
Technically, I should be using this
to cut holes in metal, but they don't have them in 3" width size, not to mention they are hella expensive! I could be wrong... The 3" holesaw is $90 bucks here http://www.relton.com/holesaw2003.html. Damn!
Just wondering what everyone else out there is using to cut holes 3" and larger.
Yeah they don't make Step bits that will do up to 3" at least not at a price that is reasonable. You could have one custom made but we aren't talking reasonable. There are hole saws that are for cutting Ferris and Non-Ferris metals (Non-Ferris = Stuff without Iron basicly, Copper, Alum). The Wood ones will likely dull quickly and not give you a very clean cut.
