l008com
- Jun 20, 2002
I'm building a custom 7 bay optical drive tower. I have all the metal I need, and I even bought a rivet gun. It worked great for the first two holes I drilled. After that, the drill bit I was using wasn't going to drill another hole. I assume it was just a wood bit anyway. When I try to drill holes with it, it will barely scratch the surface, but will get so hot from rubbing that it will actually glow bright red. What should I use to put small diameter holes in sheet metal cases? Some special drill bits perhaps, made of some other material?
