Drill bit sizes
Silent Assasin
Ok, so in the process of my new case build, I bought one of those tap screws that thread nearly any metal with a drill bit. They had several that came packaged with a drill bit to drill the hole first and then drill the threading. But for more then half the price I could be just the threaded drill bit, so I bought it at around 2.50. My reasoning is that I've got a garage full of litterally hundreds of drill bits and several friends and family members with the same situation as me, I was sure that I could find the correct size drill bit. So anyway, I got home opened it up and it says to use with a #29 drill bit... Then I thought, wtf, I've never even heard of people refering to drill bits as #'s. So anyway the thread drill bit I bought is for #8/32 sized screws, anyone happen to know exactly would diamter drill bit to used? After comparing a couple of bits, it seemed like 9/32" drill bit fits the best but it didn't fit exactly right, the first hole I drilled with it, the start of the thread was wierd. The other sizes I tried just didn't work. 1/4(Next size down) it made the threaded bit grind and I was a fraid of stripping. The next size up didn't give enough threading for the screw to catch. Is there some bit size in between that refers exactly to #29 drill bit? I even went back to the hardware store and looked, and they didn't sell any idividual drill bits by the # nor did they have a chart or anyone that could tell me what size that actually is.
Okay, 30 seconds on Google found me this page , which shows that a #29 drill bit falls between a 9/64" and a 1/8" drill bit in size.
If you don't have the correct size, it's always better to go a little larger in size, so use a 1/8" drill bit. Why? Because, as you said, if the hole is too small, the beginning threads can be a bit weird (because the tap can't get down in the hole far enough). You actually went well over 1/4" with a 9/32" drill bit, but I'm figuring you meant 9/64", right? Cuz a 9/32" hole would give you a lot of "wiggle room" all around the tap, and make it impossible to thread the hole, since the tap cutting threads wouldn't even touch the sides of the hole. :rolleyes:
Remember, in the future, Google is your friend. :D
Dood, wait till they spec a "letter drill bit" that's gonna fry your noodle. There are fractional drill bits 1/4 3/8 1/2, there are letter drill bits that follow wire sizes 1-80, and there are letter drill bits A-Z and then there are Metric drill bits. Gottem all :D
No kidding...
I bought this massive Titanium Drill Bit set from Cosco that has ALL sizing versions of bits. Lettered, Metric, US Fractional, a bit for every size and type.
I stare at it trying to figure it out, but haven't got there yet.
At least it has the good old US fractional section :)
-Larry
