Dremels
it was much easier using a jigsaw than a dremel for window cutting, i was originally going to cut a mitsubishi logo but messed up w/ a dremel and just cut out a regular window w/ a jigsaw w/ ease(sp?) :)
Ive tried using a jigsaw with a fine metal blade and didnt like the job it did, or the vibration from the lower speed it runs at. The dremels higher speed is much nicer, you just dont have the support like the jigsaw( needs a steady hand).
