Dremel: What should I get?
WeeManFoo
I would like to cut a spot for my two yate loon fans on top of my Lian Li A05 case. I need a dremel but I don't want to spend alot of money. What is the cheapest dremel with cutting tool I can get that will easily cut through my aluminum case?
Just make sure that you get a real Dremel, not a 'rotary cutting tool'. Dremels are better and have a proper motor to stand up to the stress of metal and plexi cutting use.
I paid $60 for mine at Sears, but it was the nicest model with a lot of different attachments and a nice hard case to store it all in.
Amazon has one for just under $30.
When I used my Dremel for the first time, the cutting blades ground down to nothing very quickly. I would suggest picking up a few more cutting blades if you don't get a half dozen in a pack-in with the Dremel itself.
