I've decided to do the following mods to my Shuttle SN45G XPC small form factor pc as soon as possible:
1. Remove exhaust fan grill & make it larger to fit a 92mm internal fan
2. Remove Power supply exhaust fan grill & maybe add 1-2 fan(s) on other side of ps pushing air thru
3. Make an internall 92mm Fan Shroud
4. Remove portion of bottom Hard Drive cage so hard drives are lower with space inbetween for airflow
5. Make a slit cut on front of faceplate to fit a SKINNY internal floppy drive (where can i get one?)
6. I'll put a small quiet fan or fans in front of the hard drives.
I'm going to do something similar to this person's mod, but I'll only be using 2 hard drives and 92mm exhaust fan:
http://forums.sudhian.com/mess...=61523&highlight_key=y
So, what is the best Dremel toolset for the money that will do the best job for these mods? I'll have pics when it's done too
-dejacky
-dejacky
