dremel question....
Atherton213
ive got a dremel... and i wanna put a spot for another fan on my case... do those bits that cut large holes work in a dremel? or would i need a normal drill for them
also if so... (i know this was said somewhere) what size bit for 80mm fans
Hole saws would not owrk in a dremel... if it didn't lock up the dremel itself, it would rip your arm off because you dont got anything to grip on.
Your best bet would be to go out and buy a real drill.
Dremel plastic, drill metal.
I use a 3 1/8 or 79 MM for cutting 80 mm fan holes.
Hope that helps.
Damn it! F'ed my drill up today cutting into a server case....had to dremel those fan holes...
But it's done...27 plus inches tall, with windows on both sides...
Full metal, if you put a center bit in that hole-saw of yours you'll probly get better results... just an idea.
Sounds good. Thanks. I have always been into tweeking inside of PC's, the out side mods are new to me.
Geez, duh. I just realized what you said. Yes I do use one always. It is not the pic though huh. Hehe.
