mohammedtaha
- Oct 14, 2004
Why won't Dremel add a holesaw to their kits. I wish they'd do that.
Blades are just not that great when you're cutting small holes into thick metal.
Is there an easier way to cut small holes, for example a 3/4" hole into 2mm aluminum or is a hole saw the only method?
your thoughts please ..
