i've got a 300 series dremel. it included 50 accesories/attachments. i've gone through the quick-start guide, as well as the manual, and nowhere does it show you how to attach things to the dremel. i find this to be a bit disturbing as the accessories came with the dremel. maybe my monkey brain just doesn't see it. anyways, please help me so that i don't lose a finger or an eye.
here's what i have:
300 series dremel, collet, collet nut, #402 mandrel (i think, it's the only mandrel that came with the dremel), #426 cutting wheel, and wrench tool that came with the dremel.
how do i properly attach the #426 to the dremel?
UPDATE: i found another mandrel, which I think is actually the #402. it has a flat-head screw for tightening cutting wheels.
is everything attached properly?
i turned it on to speed 10 and everything seems to be ok. nothing got loose.
here's what i have:
