Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
anyone have any suggestions as far as good dremel cutting bits. i have the one that came with my new 400 xpr but i am wondering if anyone uses any other specific bits to cut shapes out and such...anything helps, thanks a bunch.
very well as long as you keep the rpms up and go slowly.
if you search for my thread in the case modding section, you can see the cuts i did (decent pic of how they came out).....i barely have any sanding to do. i only used one wheel too, still has plenty of life left in it!
very nice, thanks for the information...i am headed to the [H]warestore today, it's like pissing distance from my house....hey btw, what case is that you have with the glass front, its very clean.
