commissioneranthony
- Jul 2, 2008
I'm looking for a rotary tool that won't die out on me in a years time. I am comparing the Dremel 4000 to the Rotozip lineup to the Dewalt DW660 because I need a reliable tool and I am not going to buy the cheapest POS rotary like tool I can find.
First off, I am looking for a tool that has some torque behind it and a high amperage motor. I know the dremel is down in both these categories, but I also want to consider the compatibility of each tool, in dealing with the accessories that can be fitted into the chuck of each tool. In addition, I want to include the size of each tool and practicality of using each tool for modding activities
The only reason why I am comparing the dremel 4000 to the other more powerful tools is because there are literally no detailed reviews of the 4000 tool online. Yeah I can read some lousy reviews that say it has a "new and improved motor" but the rest is just fanboy, under the counter, paid-to-be-made literature. I am not the biggest fan of dremels because both my brothers had 400XRP dremel's and both dremels had problems and needed to be replaced.
I want a tool that will work when cutting wood, plexiglass metal and random alloys and won't begin to smoke up and smell horrendous over time. I m leaning more toward the dewalt and rotozip because they are more commercial tools rather than underpowered consumer tools. However, I don't have any experience with any ot these tools and am in need of some advice or feedback from current users.
Also, I noticed that the biggest reason for dremel failure is beuacse of the wearing down of ball bearings. Do they make rotary tools that use syntec sleeve motors? I have researched many tool manufactures and have found out, besides the fact that they almost all divisions of each other, that black and decker, proxxon and mastercraft also make rotary tools. However they are dremel like equilivants which could be rebrands or low quality instruments that will fail in a month.
Any advice would be great. thanks for following along.
