Dream Build Thread
updawg
I am sure you have priced out computers on newegg multiple times with no intentions of buying. So this is a build I came up with: it is a super powered computer in a small case, no modding required. The PC-Q07 has only a single slot for GPU's and currently the 7770 by powercooler is the fastest that is being sold at newegg. Since the cooler on the card is 1.5 inches you have to remove the hard drive cage by unscrewing the 4 screws on the bottom of the case. That is why you will see the Optical Drive caddy that converts a 5 inch bay into a slot loading slim drive and 4 2.5 hard drive mounts. To reduce clutter I went with the smallest modular PSU and included the short cable set. I have no personal intentions of buying or building this computer but I always find this fun to do. Please post your dream build or comment on mine to see what people are interested in at the moment.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811112227
Optical: http://www.newegg.com/Product/Product.aspx?Item=N82E16817997041
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814131477
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817256065
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147096
MB: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131840
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233
HD1: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136927
HSF: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103177
HD2: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147164
PSU Cables: http://www.newegg.com/Product/Product.aspx?Item=N82E16812162010
I still have a few fans and other items to pick up but this is what I have so far to start the build today:
