Greetings,
I'd first like to start with my present computer spec. (Click the links for specs)
Motherboard: Gigabyte GA-K8N-SLI
Processor: AMD Athlon64 FX-55
Memory: OCZ PC4000 Dual Channel kit (2x512Mb)
Graphics: BFG Geforce 8800GTS OC 640Mb
Power-supply: Coolmax 550W PSU
Cooling: Zalman CNPS8000
That makes up the base of my computer, and it was a trouble free install. I plugged the PSU into the motherboard using the 24 pin connector.
The CPU and memory were from my previous setup that can been seen in my signature.
Problem:
No matter what I do I always get random BSOD, no specific blues, but entirely random ones. I've installed Windows XP, Windows XP SP1, Windows XP SP2, Windows Vista and Windows 2k with SP4. All of these start blue screening right after I've finished installing the OS.
I've tried all possible combinations of drive setups, 2 x 74Gb Raptors in RAID0 (on SATA), single SATA drive, Single ATA drive, I've even tried a single ata drive and not a CD drive (installed Vista from a USB thumb drive).
I've run memtest86 for roughly 12 hours and no problems with that. I also ran Hot CPU tester Pro, diagnostics mode but it failed the complex matrix in the third try, but nothing else failed.
If anyone could point out something I've done wrong or some items that are incompatible please do, I'm at my wits end!
Problem:
