mulpsmebeauty
- Aug 1, 2004
Apologies if I should know the answer, but I haven't come across it in my readings on this forum. I have an Enermax Noisetaker 600W, with 2 x 12v lines, each capable of supplying 18A. One is dedicated to the motherboard, and is providing juice for:
- AMD 64 3400+ (stock speed)
- 6800Ultra via AGP port
- 1x 80mm case fan.
The other rail is giving juice to:
- 2 Molex connectors into the 6800U
- 1x 74Gb Raptor, 2x 160Gb SATAs
- 2x 120mm fans
- 4x 80mm fans (yes it does sound like a freight train)
- CD and DVD drive
I have another (a fourth) HDD for the second 12v line which isn't plugged in yet, and I want to overclock the GPU. The question - will the two 12v lines pool their resources? The manual quotes a maximum total of 35A. It seems like the second line is getting a bum deal with supplying umpteen drives and everything else if it's limited to 18A.
- 1x 80mm case fan.
- 2x 120mm fans
- CD and DVD drive
