Meesterjojo
- Oct 31, 2009
Howdy!
In another thread I detailed how I RMA'd my GTX 260 MCOCX and just (yesterday) received back from BFG a GTX 285 OCX. Cool. So I thought I'd hook up my 46" Samsung to it.
Everything was fine...to a point- Dragon Age wants to flash these...artifacts- almost angular black things that cut across the screen. They flash to fast it's crazy, but they don't stop.
Running at 1920x1080p, and I had even tried lowering the resolution waaaaaaaaaaay down from there with the same results.
Other games played have included Stalker, Fallout 3 (completely maxed), Oblivion, and The Void. The void heats up the GPU like no other, but no problems really. Even stalker had zero issues (other than heating up a bit). DAO is the only one to show these artifacts.
I thought, too, it might be heat related, so I it cool down, rebooted my system, and tried- same thing. Bummer.
Nvidia issue? Heat issue? What could I look for?
Advice- much thanks!
