DQ45CB and raid controllers
Discussion in 'SSDs & Data Storage' started by OrakelJos, Oct 17, 2009.
  1. OrakelJos
    OrakelJos n00b
    14
    Apr 29, 2009
    Has anybody experience with the Intel DQ45CB motherboard and the use of an external raid card like the Areca, Adaptec or 3Ware controllers?
    I have read some stories on the Intel forum about boot problems when using raid cards in the PCI-e 1x and 16x on this MB.
    Because I want to use this MB with ESXi and using VMDirectPath (which this board supports) with an Areca 1210 this info would be vital for me.
    I also want to use pass through on 2 Hauppauge HVR-2200 (European equivalent of the HVR-2250) tuner cards so any comments and/or experience on that are also very welcome :D
  2. justin2net
    justin2net n00b
    53
    Oct 4, 2009
    With regards to this post: http://forums.anandtech.com/messageview.aspx?catid=29&threadid=2277059
    I believe the user did not enable the "show extension card BIOS" feature in the motherboard BIOS. When this is enabled, the banner screens will appear from add-in cards, including NICs and RAID cards.
    Also, there IS a way to disable Intel AMT. Go into the AMT bios, hit disable, reboot.
    One more thing...ESX(i) will passthrough up to two PCI(e) devices per virtual machine.
  3. OrakelJos
    OrakelJos n00b
    14
    Apr 29, 2009
    Thanks, but I read about a different problem. The user was able to use the raid card but after a restart the machine would not boot till the drives were physical disconnected.
    I was referring to this post: http://communities.intel.com/message/68208
  4. OrakelJos
    OrakelJos n00b
    14
    Apr 29, 2009
    After purchasing the DQ45CB I can confirm that a Perc 5 with the two pin mod is working. Have to sort out a couple of problems with ESXi and file corruption.
