Downloading in Vista
sasquatch
My friend has an HP laptop that came with windows vista installed, back when vista first came out (the day of, in fact). She keeps it updated and scans for viruses and such very regularly. A while ago, she discovered trouble downloading .exe files. She asked for my help.
What I found - the computer will go through the normal file download stuff, download the file, and then the file will disappear. I've tried to download to different locations, and no matter what I do any file over 1mb downloads completely and then disappears. They don't go to the recycle bin or anything, and a full search for any part of the file name brings no results. Is this a protective Vista security feature? Anyone have any ideas? I chatted with HP tech support for an hour or two, but to no avail.
Help!
Have you tried downloading to a thumb drive and then opening the thumb drive on a separate computer to see if the file is there? Let us know how that goes.
Tried it, and the same thing happened. The file appeared to be downloading normally, then appeared on the drive for a second, then disappeared. Doesn't show up on any other computer either. Suggestions?
I have seen this. I am guessing she runs Norton. It is a conflict between Norton and Windows Defender. The file downloads to the temp folder, and then on transfer to the location you saved to it is deleted. If I remember correctly, Windows Defender needs to be disabled or repaired. Or Norton removed.
She doesn't run Norton, though it may still be installed. She uses avg. I'll check out Windows Defender anyway. And to the other person, the same thing happens in firefox and IE.
