collegeboy69us
- Jul 27, 2003
hi all
i have a koolance PC-650C i think thats it anyways, the 12" aluminuum radiator leaves a little to be desired... its so thin!, i was curious as to: if i bought another radiator exacly the same as that, and got longer bolts and just kinda double stacked them to where it flows in one... then the 2nd one, would that effectively double the heat dissapation?
Would that be something you could reccommend doing?
reason i ask this is because i wannna beef up this koolance a bit more but wanna keep things as simple as possible. I'm considering getting a new pump, and res, still looking at options. I want to keep everything as simple and clean as possible. Keeping in mind i wanna keep everything aluminum too (dont wanna mix copper and AL at ALL)
I'm open to any and all advice
oh yes, reason i bought the koolance case? it looked awesome to me, and besides who doesnt like a little fixer upper
THanks
Jeff
THanks
Jeff
