Doublesight DS-265W - Pros & Cons.
Cyane
I've been strongly considering purchasing the DS-265W, but have read a lot of mixed reviews from other users. I was just wondering if anyone has this monitor or have used this monitor that can point out the pros and cons before I invest $650 into it.
Another option seems to be the HP LP2475w, which apparently is getting pretty good reviews. So far my choices are these two.
P.S. - I'll be using it for Gaming and HD Movies mostly. Recommendations for equal or better IPS Panel alternatives in 24" to 26" bracket would be great if the DS isn't worthy.
Cheers.
