Double the video memory?
Is there a way to disable this through the Nvidia settings? I definitely won't be using anything more than the 256 it has onboard the card.
As far as I know there is no way to disable the Turbocache short of flashing the card with the BIOS from a non-turbocache enabled model.
There is no need to disable turbocache anyway - the system ram that turbocache uses isn't 'reserved' all the time and is only used should the need arise.
I wasn't even aware this card has Turbocache features. It's not even listed on the datasheet for the card.
EDIT: I just read a review on Anandtech's site, and it lists Turbocache as a feature. Well, mystery solved...thanks!
