So, not sure if anyone is familiar with a research program Google is doing, but the short is that they will pay you $120 up front and $30/month if you install a Cisco router that will report your internet activity to Google as part of a large research program. I figure I already use Google Chrome browser, so Google probably can already see what I'm up to, but hey, if they wanna know I look at pictures of funny cats and pay me, so be it. However, that also means I'll be sending them info about by banking, email, etc. which isn't good.
So my question is, what if I wire the special router they'll send me into my network behind my existing router? Specifically, internet comes in via a Motorola SB6121 and then to my WAN port on the WRT54G. From the Linksys I've got a hardlined PC and Xbox and then via wifi my smartphone and a tablet. Google requires a minimum of 1 device for the research and it can be a tablet. So the thought is I'd run a line from an open port on the Linksys to the WAN on Google's Cisco router and then on a completely separate wireless network, connect only the tablet. Then, as long as I use the tablet for general stuff and refrain from accessing private data on it, Google gets it's research data, but not banking data etc. that I do on my desktop that's on the Linksys router.
Does this make sense? Would it accomplish my goal to feed "piddly" data such as YouTube, Netflix, lolcats, and etc from my tablet and not send them private data from banking sites and other things that I'd do on the PC? Assuming worst case that I can't access the provided router's settings interface, would this still work?
Below is a simple diagram I made to help.
