bobn4burton
- Aug 19, 2002
Quick question...hopefully it'll be an easy answer. So a friend of mine has a qwest dsl modem/router (M1000) with no wireless.
He has a gig switch behind the qwest router for all wired connections. He is then using a Linksys wrt54gl router hooked into the gig switch for wireless access. Everything seems to be working fine...except for a couple little quirky things.
For instance, he has a Windows Home Server box wired to the gig switch. When he connects wirelessly with his laptop...he has trouble accessing the WHS box. Backups don't work and using the computer name to connect via Remote Desktop won't work (inputting direct IP does).
The routers use the default configs (qwest modem on 192.168.0.x and linksys using 192.168.1.x)
I'm guessing I just need to tweak the setup somehow to make the things work better??
In the future I want to disable the router in the qwest modem/router and just use the linksys for routing, but don't want to attempt that until I can be there to help him (currently helping him via remote desktop/phone)
Thanks for any insights...
