double check my numbers plz.
import
im running a q6700.
obviously multiplier is 10x.
fsb is 300. so posts at 3.0ghz.
voltages are on auto, so they are:
core voltage is 1.325
fsb voltage is 1.40, and shows up as red in the bios. iirc, i set it one step down, to green, it posts but takes longer, so i just went right back into bios and set it back to where it was.
So what exactly do you want? We can't tell you what the right voltages for you are going to be.
I have a question for you. Do you use the fan on the NB on ur motherboard? According to various reviews the fan is unbearable. How hot does the NB get?
i have it on, and its on auto through the mobo.
i don't know what the temps are though. where can i locate the NB temp inside CPUID?
i was just worried that the voltage was showing red, and wanted to know if it was typical.
as for the nb fan, i have it on, and its on auto through the mobo.
i don't know what the temps are though. where can i locate the NB temp inside CPUID.
