I'm not 100% sure, but my memory benchmarks seems kind of slow, would you mind commenting on it real quick? The reason I ask is because my Windows Experience index is 5.9 for memory. Normally, I wouldn't be too concerned because I know you can't trust the WEI too much, but another computer with just about the exact same specs as me got a WEI index for 7.3, which I thought was a pretty big significance. The only thing different is that he was running Corsair and I'm running OCZ memory.
Here are my specs
- Core i3-530 (not OCed)
- GA-H55M-UD2H mobo
- OCZ Gold 4GB Dual Channel DDR3 running at 1333MHz
- Running Intel HD Graphics with 128MB shared memory
Here is what CPUZ reports for my memory
Type: DDR3
Channels#: Dual
DC Mode: Symmetric
DRAM Frequency: 666.7MHz
FSB : DRAM: 4:20
CAS# Latency (CL): 8.0 clocks
RAS# to CAS# Dealy (tRCD): 7 clocks
RAS# Precharge (tRP): 7 clocks
Cycle Time (tRAS): 16 clocks
Row Refresh Cycle Time (tRFC): 60 clocks
Command Rate (CR): 1T
And here are the benchmark results from CrystalMark2004
Read : 8965.72 MB/s ( 8965)
Write : 7088.09 MB/s ( 7088)
Read/Write : 6457.53 MB/s ( 6457)
Cache : 65152.06 MB/s ( 6515)
Here are my specs
- GA-H55M-UD2H mobo
Type: DDR3
Channels#: Dual
DC Mode: Symmetric
FSB : DRAM: 4:20
