dothan in p4 mobo
ryuji
will a generic no options bios'ed laptop mobo be able to safely run a dothan... this northwood p4 2.8 is sucking too much power
Are you trying to put a Dothan in a motherboard designed for P4s? If so, then that's not gonna work. Although the chipset can run the Dothan fine, the pin outs are different, yeah? So if you pop a Dothan in there, you will most likely kill something.
if powerleap decided to make an adapter for that...that would be grrreeeaaattt. :D
i think my friend took what he said was a dothan out of a laptop and put it in his ic7 and it ran quite well....4.2 ghtz well... when stock is 1.somthing i belive
could be because the ic7 kicks ass...
the current fastest dothan runs at 2ghz, your friend lies.
maybe it isnt a dothan then.. i seen it first hand run at 4.2 tho he also says dothan owns the a64 fx-53 939 when overclocked
dothan's are very fast, easily faster than any amd or intel chip. but your friend must have had a p4, proboboly a 30cap 3.0 or some prescott.
im sorry about before, i didnt mean to sound like a jerk but the only people ive seen that have overclocked dothans or any Pentium M's are people with notebooks and they modify the bottom of the laptop with big heatsinks.
