Everytime i fixed the selected problem of this DOS exploit found on this computer i'm building it comes right back.... is there anything i can install or something that will take care of this?
I would first turn off System Restore, so you don't make a backup of the damned thing. Then, I'd run HijackThis, and see what it is called. Next, I would use regedit to find it, and any dependencies. Last of all, I would remove it from my registry and its associates, and keep my fingers crossed in the hope that I didn't kill the install. I tinker with the registry all the time, but if you don't , BE CAREFUL.
I killed a few installs learning. Actually, more than a few.
Yeah it finds DSO exploits every now and then. Usually you find them on a fresh install, i think it could be due to not having all your windows update patches installed as well. You should be safe just to remove them, I have never had a problem but you can back stuff up to be safe.
