Ieldra
I Promise to RTFM
- Mar 28, 2016
I think the fact that DOOM uses Denuvo is the reason why it can't run on Linux.
Denuvo; the eternal asshole
Problem is would you really run a 256-bit bus with 4K?
It is a bottleneck that has been shown in the past when comparing previous gen, and one reason 390/390x could perform better than 980 by benchmarking at 4k rather than 1080p or 1440p.
So unfortunately the 1070 is not ideal for such a test.
Cheers
Ah well that sucksI think the fact that DOOM uses Denuvo is the reason why it can't run on Linux.
Although Nvidia clearly state 4k with 1080, 1070 with 1440p.Well last year's AMD video cards in the $380 - $500 cards certainly could run 4K; just needed to turn AA levels down or off. The Fury X has been lowered to as low as $399 recently which places it directly into the same value category as the GTX 1070. So I agree that the Nvidia GTX 1070 isn't designed for 4K gaming as it is a replacement for the GTX 970. But unfortunately it is in the same value category as the Fury X due to it's exorbitant pricing model which far exceeds last year's GTX 970 pricing model which capped at $329 on the high end. A better comparison would be between the Fury X and GTX 980ti as they are designed from the ground up to be a much more capable 4K solution than the GTX 1070.
Truth is that most people shop according to what they can afford. Nowadays you can get the GTX 980ti and Fury X, for slightly cheaper than the GTX 970 replacement called the GTX 1070. Thus Digital Foundry and you were correct in the collective assessment that the GTX 1070 is being tested out of it's category for this comparison. But it is a valid test because that's where Nvidia assigned it's value category to the silicon it produced. If Nvidia wanted a GTX 1070 vs R9 390(x) / regular Fury test, then they should have priced it accordingly.
It is what it is.
Even they do not market the 1070 as 4k.
Price well, AMD has always had to price their cards cheaper but if you want to do that then launch price VS launch price... and the Fury X is not same.
IMO they should had tried PresentMon or not bothered.
How many will use 4k test as a reflection of their 1080p and 1440p buying?
Which is the majority with the card unless going mGPU for 4k, and even then I would not be keen with a 256-bit bus, they never even make a caveat about this in the test.
So for everyone the test is basically meaningless, apart from knowing what we always did that FuryX is pretty good at the higher resolutions.
Cheers
Why do you get to decide it is $449?Sorry but if you have a 4K monitor then you're going to be shopping in the 4K priced video card section. $449 is a 4K video card price. Heck $380 should be entry level 4K video card pricing as the AMD cards can run 4K at those price points at the entry level easily. Like I said Nvidia says it's that price for a reason; because they are absolutely sure that it has that performance. Thus it should be compared against it's equally priced compadres.
Don't believe me? Note that every video card test on [H]ardocp is arranged by pricing value for a very good reason!
LOL one of my friends sets his pricing to a maximum of $4.50, once in a blue moon he will pay maybe up to $9You know it is funny how publishers are all excited to add DRM, but then lower the price of the game to $35 a month after release to generate more sales. It's like they created tiers of stupidity for consumers.
$60 dummy who pays to beta test the bugs.
$35 conservative that pays to less for a few bugs.
$20 cheap guy that thinks he got a steal because there was a guy willing to spend $60 three months ago.
$10 guy that thinks he scored during the next year's Steam Summer Sale.
And finally the $7.50 person that just cleared Asteroids off his backlog and is going to take another 3 years to finish Doom.
How much was the Fury X when released when people were buying that?
If you have a 4k monitor you would go Nvidia 1080 single card because of the headaches of mGPU that is exacerbated with current DX12 games.
The Nvidia 1080 is the only single card that in practical terms can support 4k with enjoyable settings and performance.
If you want to use current pricing, well the 480 is not the best priced performance card because you can buy custom OC 980ti cheaper than the 1070 and cheaper than the FuryX now - price context goes beyond just Doom Vulkan.
Where do you draw the line.
Anyway again you do not use a 256-bit bus card for 4k, it has been shown for many reasons and price does not change the fact, if they benchmark they need to show the 1080p and 1440p as well, if they cannot then they should not benchmark.
Would you be happy if the FuryX was only shown with its poor 1080p performance because hypothetically they could not benchmark higher due to technical difficulties?
Cheers
Since it's textures popping in, I'm gonna go with the obvious answer: VRAM.Texture compression? Bad drivers? ID got paid off to make it load slower on Nvidia hardware? Rage 2.0? Maybe this is why Nvidia users keep saying that Quantum Break looks bad?
Well actually it should be less than that. I chose $449 because that is the MSRP of the GTX 1070 FE. The R9 series can run 4K with small concessions for less than that. So if you price your video card above the $400 tier then you're in 4K gaming territory. That's the consumer's expectation based on pricing. Consumers don't care about your bus speed; only your perceived performance doing what they intend to use your card for. It has already been established that since the R9 390x has been out, that you can do 4K gaming for that price range.
What does the Fury X release price have to do with it's current pricing? Especially when a regular Fury is almost as fast and the same price as the GTX 1070. Guess what? It can do 4K also. Nvidia overpriced their wares if the GTX 1070 can't.
Most people don't want to spend $699 on a video card. That's why there is an entry level 4K section at the $400 price point. Scary to think that people don't naturally buy the most expensive thing, even if they can afford it, if another device will get them a "good enough" experience. GTX 1070 is a good enough experience at 4K; just not as good as others in it's pricing tier for various reasons.
You can play games at 4K on the 980ti just fine. People have been doing it for years. Guess what else? You can play them on the Fury X, Fury, and 390x also. People have been doing it for years on those cards also.
People that spend $199 on a video card are not looking in the same value category as someone spending $399 on last year's flagship. Sorry but your assertation of budget categories is off. I used to sell electronics. I've never talked a person looking at the $199 section for a video card into spending $399. I could get them to $250 if they were younger and had that look in their eye. $199 budget bumped to $399? They were just a cheapskate from the beginning and lying about what they wanted.
Nvidia doesn't care about their bus limitations and market the card as the second coming of Christ. Why are you doubting the creators of the video card about it's relative performance to other cards in it's price value category? It's a good enough 4K card; just not the best at it in it's pricing tier. I agree with the video creator on that assessment.
if that were true then why did the cards have plenty of unused vram left over? lol i think its cause nvidia cheats!Since it's textures popping in, I'm gonna go with the obvious answer: VRAM.
Edit: Other reports indicate it's also affecting the 1070 and 1080, so not related to vram capacity.
Cageymaru,
in fact DF agree.
They have just done a video specifically looking at a GPU to play at 4K...
And that is a Nvidia 1080:
Even saying other GPUs do not have the power for true 4k gaming.
And would you really want to play Doom a fast FPS with framerates of 43-53 average range, even dropping down to 37 FPS in places, without Nightmare shadow setting that requires more than 5GB VRAM.
So why would it seem right to test a 1070 with a 256-bit bus at that when even the Fury X is not actually ideal-playable in a fast FPS itself.
The price argument just does not fit even with the factor of saying one would only pay that price for 4K gaming, as shown by the variance in Vulkan FPS (and that ignores DX11 and DX12).
Anyone 4k gaming is either going mGPU or having to buy a Nvidia 1080 unless really toning down settings, and either way this is quite a bit above the price of a single FuryX or Nvidia 1070.
Cheers
You ever played Doom or twitch FPS at 30fps?There is more to the story. There are 2 sets of parameters when talking 4K: 60fps and 30fps. This is what you find in different sites and even AMD marketing, that 30fps is the metric for PLAYABLE. Sites like [H] set ~60fps as playable. Then you have arguments for how much AA is even necessary and other settings that are really personal decisions (like I never use DOF or radialblur, cant stand either). Either of which can greatly affect performance and dictate whether a GPU is 4K capable or not.
Rest matters too.xx
if that were true then why did the cards have plenty of unused vram left over? lol i think its cause nvidia cheats!j/k....they could be though
Trust me I wasn't making claims to which is better but that personal preference and even ignorance (as to what framerate a game is actually at) is the true metric for an individual. I generally prefer 60fps. Set some to 30fps back in the day for experimentation and seemed slow and not better than 60fps when unstable frame rates. But there was once when I was playing a game for a while and it was fluid and played where I thought it was 60fps. Saw some reviews that showed my GPU not producing 60fps so loaded FRAPs and lo and behold it was running 24fps like dvd, it was locked/capped via some setting for that. So what I have noticed is some games will tear like a mofo and others just seem smooth no matter what, so case in point just depends on personal preference and games you play. I prefer RPG/open world and tower defense, not a huge FPS other than Halo and intently looking at Doom seeing these reviews.You ever played Doom or twitch FPS at 30fps?
I agree but there is limits to 30Hz and 30fps gaming.
Cheers
Yeah agreed, there is a place for both, less so the 30Hz if using a broad range of 1st person games though IMO.Trust me I wasn't making claims to which is better but that personal preference and even ignorance (as to what framerate a game is actually at) is the true metric for an individual. I generally prefer 60fps. Set some to 30fps back in the day for experimentation and seemed slow and not better than 60fps when unstable frame rates. But there was once when I was playing a game for a while and it was fluid and played where I thought it was 60fps. Saw some reviews that showed my GPU not producing 60fps so loaded FRAPs and lo and behold it was running 24fps like dvd, it was locked/capped via some setting for that. So what I have noticed is some games will tear like a mofo and others just seem smooth no matter what, so case in point just depends on personal preference and games you play. I prefer RPG/open world and tower defense, not a huge FPS other than Halo and intently looking at Doom seeing these reviews.
There was no texture pop-in for me at all with a GTX 1080. Beat the game in OpenGL, and played a few levels in Vulkan. I think settings were on High.
Also, Quantum Break is one of the best looking games out there, bar none. Anyone saying otherwise is straight trolling.
Yeah, I was having some bugged out issues with Surround on the 69 driver (haven't tried since 81). It may be because of SLI and/or G-Sync, I couldn't get it to work with everything enabled. I've just disabled Surround for now, and things are a lot more stable (and SLI + G-Sync still works without flickering).
DOOM in Surround was crazy, though. What an amazing ride.
The argument really sound like an oxymoron though, most people who doesn't spend $350+ on a GPU would be VERY unlikely to own a 4k monitor (even a bargain bin 4k can be easily over $400), and probably even fewer of them would want to try hooking them to their own 4k TV's and use that as their monitor.Well actually it should be less than that. I chose $449 because that is the MSRP of the GTX 1070 FE. The R9 series can run 4K with small concessions for less than that. So if you price your video card above the $400 tier then you're in 4K gaming territory. That's the consumer's expectation based on pricing. Consumers don't care about your bus speed; only your perceived performance doing what they intend to use your card for. It has already been established that since the R9 390x has been out, that you can do 4K gaming for that price range.
Doom vulkan 1440p nightmare settings, argent d'nur
Just finishing up my 14 day shift, so i am late to this party.
Quick question, which FPS counter should I use when using Vulkan? FRAPS dose not seem to work when I switch to vulkan.
Thanks
Thanks, I did not know it existed.
Oh snap, reddit link is broken though.
Hm, so that part on async can be confirmed. And now comes the most curious result, especially in context of the game apparenly not being too CPU-heavy from GameGPU test. Apparently it's not CPU heavy on nV cards, but not quite on AMD.
