doom3 benchmarks with ATI X800 (vsync on)
vsyncer
i'm very thankfull if anyone can post the results of the d3 timedemo with an ati x800 XT and x800 PRO with the following settings (if possible):
1600x1200 high quality, NoAA, 8xAF
1. fps without vsync: ??
2. fps with vsync and triple buffering enabled (!): ??
because in my oppinion one can't play d3 with vsync off ... but the nvidia cards (i have the 6800 gt) does not support tripple buffering for opengl ... and if i enable vsync i get a loss of 17 fps and a "jumpy" gameplay ... so if the ati cards have not that loss of framerates with vsync enabled it is a reason for me to sell my gf and buy an ati card ....
i ask for that already in this thread ... if you have the time pls read my post in the middle of the site:
http://www.hardforum.com/showthread.php?t=788806&page=3
thanks anyway !!
I ran these last night, HTH.
34.6 1600x1200 Ultra No AI/VS
42.9 1600x1200 Ultra No Shadows/VS/4x AI
27.3 1600x1200 Ultra Everything on/4x AI
42.9 1600x1200 Ultra No VS/Shadows/AI
27.3 1600x1200 Ultra Everything on/8x AI
26.7 1600x1200 High Everything on/8x AI
26.7 1280x1024 Ultra Everything on/8x AI
nice fps, i cranked everything on my set up at 16x12 and it was worse than a grade 4 slideshow, haha
i get 42fps @1600 High no vysnc. x800pro A64 3400+ Cat4.9beta
using the games defualt settings
*edit* X800Pro @ 510/515 *edit*
You only getting 510/515 w/ your pro? You should be getting a lot more than that - I can bench at 595/610, but run 580/580 all the time and it's buhyoorafuhl and rock solid.
What make is it?
erm some crazy japanese make http://www.kuroutoshikou.com
it will go higher according to ATITool (never let it finish) had it at 530/530 but Doom3 locks up. The ram is 2ns
Am getting some bga sinks an a decent cooler to see if that makes a difference might even try the 16pipe thing. Not too fussed though, went from a 9600xt so 42fps @1600 is just fine :p
What make is it?
if you are getting those ocs you are the rare one..most dont get much over 550 or so..
I get around 42 fps also at 1600 HQ
I'm writing a detailed article on v-sync right now, probably be a worthwhile read for you if you're big on v-sync.
You must remember that v-sync imposes a FPS divider unless you utilize triple buffering; ATI is capable of forcing this in the CP with OGL-based games.
