DOOM 3 Settings for AIW 9700 Pro
Anybody out there using an AIW 9700 Pro to play Doom 3?
Just wondering what settings you are using to get the best results.
Thanks!
Pittbiggdaddi
I play at 1024x768 medium quality and it runs well on my 9700pro, what are the rest of your specs?
System Specs:
Athlon XP 2700+ (Stock Cooling)
512 MB Corsair XMS 3200 (2 X 256MD)
Abit NF7-S
KingWin 450W PSU
ATI AIW 9700 Pro
Been having a lot of trouble with the AIW overheating. I think this is what is causing green lines to appear. I cut a hole in my case and now have a Delta fan blowing right on the card. I hope this fixes it.
Pittbiggdaddi
i have d3 running @ 1024x768 at high settings on my 9700pro and am getting 60fps. using the new cat drivers for d3. other specs
3.0@3.6
1 gig mushkin pc 3500
i think d3 is more about memory than gpu
im using 1024x768 HQ(auto 8x AF), no AA. and i get framerates above 50 mostly. in some fights it can really get down low though. but not usually. 1 gig of pc3200 ram too
I am using a 9700TX with 1024x768 Medium, card constantly keeps locking up after few mins, i am guessing due to overheating.
My card is overheating as well. I will install the newest cats (4.9) tonight to see what it does.
2.4Ghz P4
1024m RD-RAM
ATI Radeon 9700 Pro (128mb Stock speed)
Runs on: HIGH 1024x768 2x AA
FPS: Average:40's High:60 Low:15
My system is quite old.
2.53 P4-B
512 PC2700
AIW 9700 PRO
With that system I run Medium 1024x768. I get about 30FPS. I'm guessing I'm cpu limited.
Runs fine on my 9700pro, slightly OC to 350/320
1.6@2.2GHz
512 PC2700
beta 4.9
useCache "1"
cacheMegs "256"
cacheMinK "20480"
unrared pk4
I run it at 1152*864@85Hz,high details. Frame rate is acceptable, 35fps±5
However, memory consumption is crazy. This monster game will eat 320MB on its own.
Total system memory consumption peaks at 750MB :mad:
Now that i got the 4.9 beta cats from ATI i can run at 1027x786 very smoothly at High detail.
