Ieldra
I Promise to RTFM
- Mar 28, 2016
R9 390 performing worse than a R9 380x? Something is clearly wrong with that.
That is what it looks like its only at lower resolutions where GCN1.1 cards have issues, so pixel shader and compute shaders are becoming more of a bottleneck as the res increases.
not sure haven't bought it yet, only going to buy it after the single player reviews are out lol.
I was thinking the settings used TSSAA 8TX favored the nvidia cards? Cause my goodness I had hardly a problem playing the multiplayer around 75fps at 1440p...This chart is showing 33fps lolThat is what it looks like its only at lower resolutions where GCN1.1 cards have issues, so pixel shader and compute shaders are becoming more of a bottleneck as the res increases.
I was thinking the settings used TSSAA 8TX favored the nvidia cards? Cause my goodness I had hardly a problem playing the multiplayer around 75fps at 1440p...This chart is showing 33fps lolyea ok
yes....what else? lol I see now it had a frame cap at 60 so it was that instead.....I know i remembered it not having much issues running near max frame capMe too
In the beta?
Something probably with the AMD drivers, more of a concern with AMD is just how low the 390 is.....R9 Fury X trading blows with the GTX 980. Whoa, this definitely seems off.
lol i bet money we dont see these results when [H] tests lolR9 Fury X trading blows with the GTX 980. Whoa, this definitely seems off.
It is below the much cheaper 380x and also around the 960.
Also to say regarding 1080/980ti.
Bear in mind the average is probably anywhere between 135-148fps for the 1080FE on nightmare setting against 158 for the AIB 980ti on ultra.
BUT and this is important, the max nightmare settings do hit the GPUs hard; according to the review need over 6GB VRAM to set them.
In the review link provided by Ielda, they showed a quick and dirty comparison between nightmare and ultra; Ultra was 76fps and nightmare was 56fps.
Full-HD Klickvergleich
Yeah,This is actually nightmare settings with ultra shadows essentially, who knows when the vulkan version will launch, afaik its just a vulkan wrapper
So that is a surprising result, OK the 1080 was using Vulkan but considering the optimisation benefits are yet to translate to healthy boost in DX12 for NVIDIA this still looks impressive (or at least Vulkan is working better than DX12 lol)
I see people blaming GameWorks already... in an OpenGL game.It's OpenGL. What do you expect from AMD?
Well I guess when you start getting into the 130 - 190 fps territory you're looking at CPU optimizations having a positive effect, which Vulkan could do especially if they're using a multi-threaded implementation. I don't know if the OpenGL version is using 4.5 and AZDO stuff, but id Tech folks tend to be OpenGL wizards, so who knows.
Well I have played around an hour, am gonna call it a night. First thing I did was completely max out the settings ingame, i imagine people have already started messing with console settings as well.
So far at 1440p performance has been very impressive, very very impressive. The lowest framerate dip I noticed was in the low 70s, and despite gpu load being 99% throughout my whole session, gpu temps barely peaked over 60c... 61c max
Here are some screenshots including the settings menu
you using the 16.5.2 drivers?with a 290 im getting 27fps looking down the hall in the first room at 2560 ultra
changing most settings to high dropping af or aa doesnt seem to make much difference but droping shadows to high does fps went up to 37-38
overclocking the 290 to 1200mhz got it up to 44-45fps
most the game is 60+ it doesnt drop below that very often
graphics outside of the first room are very average
looking forward to the vulcan patch and new amd drivers to get it running silky smooth all settings ultra
amd 290 seems to be running with opengl 4.3
ok first question. What are you using for an osd? havent seen that one before
yes although i tried with a older version first and the driver update made no differenceyou using the 16.5.2 drivers?
They'll fix the driver within a few weeks and get praised for beating "GimpWorks". Classic AMD.
After trying to play Rage many years ago on my HD5870, these results do not surprise me. AMD has a history of sloppy OpenGL support.
I bet a few other sites, trend on a few is for GameWorks to be blamed for everything or NVIDIA deliberately caused it, quite depressing when they then do not apply same logic to other games that work well using both AMD/NVIDIA tech, or the fact PureHair also lowered NVIDIA performance by about 5-10% in RotTR while also not giving any benefits (looks nice for AMD though especially snow).Who said Gameworks here?
Cheers
How much difference did you note on your system going between Nightmare and Ultra shadows?Well I have played around an hour, am gonna call it a night. First thing I did was completely max out the settings ingame, i imagine people have already started messing with console settings as well.
Being a pain, also curious how that setting also scales when comparing between 1440p and 1080p
Thanks as always
