Don't pee on the PSU
pahncrd
So here is the deal. I just sunk an inordinate amount of money on a new 1900xt crossfire upgrade which included of course the DFI crossfire board... little did I know that the PCIe boards need a 24 pin connector for power
I have a really good last gen PSU
http://www.ipkonfig.com/Reviews/PSUs/Enermax-EG651P/
it has 36a on the 12v rail and all that goodness.
Would it be possible to get some educated answers on whether I can use this (still quite awesome) PSU. I ordered a 20 pin to 24 pin converter, and it seems like this PSU would be good enough to support the power drain.
What do you think? Is this PSU now a POS.
You could give it a try and it might work fine if it is still up to spec after however long you have used it. You are NOT required to use a 24-pin power plug to run the mobo, but those 4 extra pins direct feed the PCIe bus. So I would suggest you make sure to use teh additional 4-pin plug and to make sure you have the cards plugged into with the 6-pin adapters.
With what little information you have given, I would GUESS you would be alright. It is worth a try. That is a good PSU and will likely support your needs. Then again, the X1900XT is a power hog and I would not think that you could plug in 10 hard drives along with them....
I recently just pulled that same PSU off our test benches here and it always did me right....till it burned up under load! ;)
True, the extra 4-pins supply power to the PCI-e slot. However, I'm almost 100% positive that if your card requires a molex connector to run, it gets most, if not all, of its power from the molex. And the X1900 obviously needs to get massive power from a molex.
The time that you need the extra 4 pins is if you run something that does not need a molex connector, since it will draw all of its power from the PCI-e slot.
I will be using an adapter so it will be splitting the power to the other 4 pins.... and hopefully the psu can handle the load.
and remember its 2 1900xts we are talking about
i ran the machine in my sig off a 20 pin PSU for a few months without any problems. you might be able to get away with your unit, but with 2 x1900s in crossfire, i would personally spend a little extra cash and get a good 24 pin PSU, just for the peace of mind.
the guys on dfi-street say that you need a native 24 pin psu like 1 million times. they wont help you one bit if you have a 20 to 24 pin converter... apparently it messes stuff up
Does anyone know the absolute best PSU I can get for under $200?
I would like it to have the 8-pin cpu connector and maybe look nifty (not required).
if you do order the zeus get it from here
it was just posted this morning in the hot deals section.
Don't listen to the people at DFI-Street. Most of them are just raving f4nb0is and don't really know what they're talking about.
I like Enermax as well and feel that they are really good quality. I don't have the one you are looking at, I've got the EG565P-VE FMA 2.0 model (SLI certified on nVIDIA's http://www.slizone.com website).
Super stable and a real performer. I had an older EG465P that I had for three years and it just wouldn't die, gave it to a friend when I upgraded.
You can get an Antec True Power 550 EPS for under 90 at the egg. Good power supply for the price, plus it has the eight pin eps connector and dual 6 pin PCIE video card connectors.
Yeah, I have two of these. One in my file server, and one in the desktop I just built.
It has all the goodies for todays stuff.
One thing - The 12VATX line might appear to be missing at first. It's not. This drove me nuts for half an hour. I thought I got a bad supply at first :)
No, actually, this PS supports servers too so the 12vATX connector support is for 8 pin and 4 pin. If yours comes like mine, it will look like it only has the 8 pin connector.
It's actually two 4-pins latched together. Separate them to get the 4-pin if you need it :)
-Larry
I have a v1.3 enermax 475... It's running fine on my Asus A8n SLI with a 20-24 pin adapter. However, I don't know how your's will fare given your video cards power req versus mine.
I can't beleive you are even asking this freaking question!
A. You just spent and ungodly sum on 2xX1900xt's and a crossfire motherboard.
B. Your PSU is out of spec and you WONDER if you should upgrade that too? HELL YES!
Get the PC power & cooling unit that was suggested. Or a Seasonic. Don't screw around with anything else if you have the funds.
Actually I have an older gen 20 pin Antec TruBlue 480 and it works perfect and I only have it plugged into the first 20 pins of the motherboard. Havent had one problem yet.
I just got an enermax liberty 620 watt, it got a good review, was much much cheaper than the PC P&C, it is modular and fits in regular ATX space, much smaller than some other PSU's with it's ratings. Also uses a single quiet 120mm fan for cooling.
blah you should have gotten the enermax, screw 80mm fans and why not go modular and have a standard size PSU for less money :p Slightly less power, but everything is on 2 rails.
I know what you mean about getting rid of your old one, I just ditched my 550 watt last gen...Luckily I can sell it to the parents since they want my old computer :)
Yeah the next standard will probably have 2 more pins that are absolutely required. Oh well, I guess the engineers are having more and more trouble getting enough power to everything. Especially when people insist on going so cheap on PSUs.
I bet folks would still try and use AT PSUs if they still fit the plugs.
One thing people forget is the ability to adjust the voltages on these PC P&C PSU's.
No voltage fluctuations at all either.
Haste266 said:
please dont tell me you ordered it from there. $70 more than the link i posted yesterday.
Alas, I am indeed that stupid. In all actuality I had about 10 other things I ordered at the same time, so it was just simpler to pay extra. Besides that I know I can count on newegg.
read a few posts up, the ZEUS 650WT also has this feature
Do you happen to know how to adjust voltages? Is there an optimal voltage setting?
Also I noticed that the 24 pin plug is missing a wire on one side that is described in the manual as a white wire -5volt. I checked the pictures on newegg and elsewhere and it seems that it just isnt there on any of them. I wonder why they have it in the diagram in the manual.
to adjust them, there are little holes in the side with a screw like object down in the hole. you turn the screw to adjust,(simailar to the PC P&C)you will need a multi-meter to adust properly but it comes preset. about the -5v, if it doesnt have it(i would have to look) most new boards dont need it and if they do, usually they can make it on their own
Thanks for the info. I don't think I'll be messing with the voltages. I decided to add a couple of raptors to the mix, so now I am really glad I got the new PSU. I <3 my tax return.
