Don't laugh it is just a question
Troney1169
Hi i'm thinking about water cooling but not to cool as much as to quite my comp down. I have decent temps right now about 32 cpu and 25 case so i don't need to get much lower for cooling because i don't overclock. I was wondering if i put in water cooling would i be able to keep about the same temps if i use passive cooling on the radiator? I just want to cut the fan noise down.
Well, zalman make a passive rad thats does exactly what you want, but its not that cheap. I doubt a normal rad would work though, because the zalman is pretty large to make up for the fact it has no fan.
like i mentioned in another thread thermaltake has a new passive one out called the rocket.
link to where its available to buy right now. only place i know of
innovatek also makes passive watercooling kits.
and any minute now........i'm hoping that top nurse will come on to sing their praises...........
please don't remaint silent just to spite me. :)
theres also some types og big heatercores, that can be used as passive,
Something smarter would be to get a chevette 77 core, and get 2 ultra quiet salman fans, and put them in silent mode, your temps will be fine with no OCing, and apperently the fans are near silent (quiter then an HDD)
I would highly recommend you listen to a 120mm fan before you consider passive, they are insanely quiet compared to 80mms. A nice Panaflo or Nexus/Yateloon fan is completely silent.
didnt catch the no oc thing but your right a reserator would be better for someone who doesnt oc
Well better late than never...
How about this little sweetie pie for a measly $120? Throw in an Eheim 1046 for another $50. And how about a Koolance CPU-200G waterblock for $20. This will do exactly what you want it to do for under $200 and even give you a little room to OC your little beastie. :D All components are compatible in the low flow school of thought and BIB is not true especially in silent passive systems. You would not even believe the little tiny pump inside a Reserator. :eek:
Just go to your local Autozone/Pep Boys/etc./junk yard, and buy the biggest copper heater core you can find, for about $20-$30. Stick barbs in, and viola, now you have your own passive rad that will barely go above ambient.
If you're going for silent only.
there are a bunch of very quiet air cooled solutions out there.
