Don't know much about cases
Framerate
Sorry if this is a little out of place, but I figure that it's the most fitting place to put it, but I want to build a PC, but I don't know what kind of case I should get. Well if anyone can help me that would be great.
Depends on what type of PC you will be building, whether noise is an issue, how much space you have etc.
Some more details would be helpful.
Depends on how much space you need. There are Micro ATX cases, Small form factors, Mid-towers, server towers, etc. First you need to figure out what size case you need.
Research all the parts for your pc out first, price check every place. If you do get a motherboard no matter which kind, don't make the mistake of getting the wrong size case just because the motherboard won't fit.
Post the specs of the PC you wanna build and what you plan on doing with it (physically), are you going to run Air or Water cooling, how many fans do you need/want, does size matter?
details plz
are you in for the looks?
do you want a nice looking cases with windows and fans and pretty lights?
or do you prefer modding?
your question is too general, give us some specs or ideas of what you're looking for
Maybe its just me, but I thought you need some extra room for the watercooling kit. Or maybe I'm looking at this wrong?
i saw a WC setup in a shuttle
anything is possible i guess
