Don't know how to install robotic drive
Don Khaled
- Operating system used: windows 2003 SP2 (Just installed it on server)
- Backup machine using SCSI
- Backup machine type: HP StorageWorks 1/8 G2 Tape Autoloader
Firstly, the machine's drivers are installed through backup exec 11d (I checked that under the device manager it shows the correct drivers). PLUS, when I reboot the server I can see it showing just before it is going in the windows.
Secondly, I am seeing the name "HP 3" under the stand-alone drives in the symantec backup exec 11d. So I believe the backup exec is able to see it through the software too.
The problem, I can't create the robotic drive as I used to do with older versions for the autoloader. Maybe this new machine with the new concept of magazines is different?
I have a single drive SCSI backup machine which I put on the same server and it works fine (backing up and restoring). But don't know what to do with the autoloader which I have.
