donde esta plasma!?!?!
maxedoutcc
grettings fellow [H] members.
I come to you searching for a place to get a quality 42" plasma. ED is fine with me since it will be for bedroom sake and i don't NEED hdtv. the usual ebay and froogle search net companies that are all over the board so I turn to outside influences.
can anyone recommend sources I can go to for plasmas? (aside from the usual B&M stores)
B
Panasonic 42PD50U, I believe is their current ED plasma. It's excellent. It can be found for well under $2000 and has plenty of inputs and other options to satisfy. The PQ is probably the best there is in terms of current ED plasmas.
