System Configuration:
Lian Li PC75B Case
(2) Rear Fan, Panaflo 80MM, 40CFM Intake
Rear Fan, Panaflo 120MM, 115CFM Intake
Floor Fan, Panaflo 120MM, 115CFM Intake
(2) Front Fan, Panaflo 80MM, 40CFM Intake
AMD Athlon 64 3200 Venice, LBBLE 0516 GPDW, 295 x 10Mhz
DFI nF4 Ultra-D Motherboard
(2) Crucial Ballistix PC3200 256MB, 2-2-2-6, 1T, 2.7V
(2) Hitachi SATA II 80G (RAID 0)
Hitachi SATA II 80G (Backup)
Abit RX300SE Video Card
Lite-On 1673 DVDRW
LS 120 Floppy Disk Drive
Antec Neopower 480W Power Supply
Dominator Pro 437W TEC CPU Block
Mean Well S-600-24 Power Supply 5 1/4-in. Bay-Mount
Lian Li Expansion Drive Bay Grill Mean Well Exhaust Vent
Swiftech Pump Relay, Version II Mean Well AC Power Control
(2) Airplex Evo 240 Fan Grill
(2) Black Ice Extreme II Radiator Internally Top-Mounted
(4) Sanyo Denki 120MM,102 CFM Fan Exhaust
Mean Well SD-50A-12 DC-DC Converter
(2) AquaXtreme 50Z-DC12 Pump @ 14.0V
Dual 3 ½-in. Bay Reservoir
Masterkleer General Purpose Clear PVC Tubing 7/16-in. ID, 3/16-in Wall
Crystalfontz Model 634 4-Line LCD
Digital LED Volt & Amp Meter w/Shunt on TEC Power Supply Output
Coolant Temperature Metal Probe/LCD (+/- 1C Accuracy)
* Cold Plate Temperature Metal Probe/LCD (+/- 1C Accuracy)
* Probe embedded in cold plate. Probe tip located over CPU center area.
Conditions:
- All case panels installed.
- All (10) fans running at 12V.
- TEC PS Output = 19.9V @ 24.6A
- CPU Core Voltage (V) = 1.54 as reported by CPU-Z via BIOS
- CPU Core Power (W) = 126 - estimated
- Pump Heat Dump (W) = 23 - estimated
- Room Temp (C) = 20.3
- Load Time = 60 Min.
- CPU loaded using Prime 95 with large FFT setting, maximum heat.
- All readings taken at end of noted time period.
Results:
- Coolant Temp (C) = 30.4
- Cold Plate Temp (C) = -14.6
- CPU Temp (C) = 5 - as reported by Motherboard Monitor via BIOS
Lian Li PC75B Case
Lite-On 1673 DVDRW
Conditions:
Results:
