Domain workstation will not retain resolution
Cerulean
This workstation has a flaky onboard Intel chip, so we have a new GeForce 2 MX220 that solves the issue.
However, when using the GPU it will always reset to 800x600 on a reboot. The onboard Intel chip does not reset its resolution.
Solution? Ideas? Help? :(
It sounds like a grou policy that forces the resolution to change to its default...Check that out first...
Sysadmin isn't here. Are there any programs out there that can check/force a resolution?
