Domain Name Transfer Question
Robizzle01
I have two domain names with godaddy and one that I got with yahoo because they were cheaper. I bought the yahoo domain name as a 5 year plan because yahoo's price seemed so great. However, as i've used yahoo for several months, i've decided that I don't like having my domains split between two registrars and yahoo seems to be very buggy and sluggish. Even though i'm not making changes to the domain very often (maybe a few times a year at the most), I still am sick of yahoo and want to move it over to godaddy.
My question, from what i've read on godaddy it looks like they will move the domain name over and extend the registration for 1 year for $7.95. However, I want to double check before I go ahead and do this. I will not be losing the 4+ years that I already have registered with yahoo will I? In other words, after I switch to godaddy, will my domain be registered for 5 years without any recurring expenses until the end of that period?
I believe that is correct. You can call godaddy and find out for sure though. They have 24/7 customer support. Or you could just send them an e-mail.
You should be asking godaddy this question to be sure, they could have some "fine print"
You should not lose any time on the domain, make sure you unlock the domain in yahoo, then initiate the transfer from godaddy. It will take about 5-7 days to get approved from the registry. Also the transfer will fail if the domain was registered through yahoo less than 61 days ago. It would also be a good idea to match the whois information on the yahoo domain to the information within your godaddy account.
Hope it helps.
