Doing a wire shave mod on PSU for uSFF project
janas19
I've been mulling the idea of a wire tuck for a while, but this is the first time I'm actually doing it. My goal is a super clean look that will be about the same as a modular, for much less money.
Since this is my first PSU wire shave and since I currently don't have a desktop and am trying to speed things up, it's not going to be super refined, I just need it to function. So this run is basically a practice run for the next one when I will really take my time and use an exact model, rather than a donor PSU.
So basically, all I've done so far was remount the 120V receptacle to the side of the PSU. Why? Simply the configuration is much better and cleaner for a uSFF box. The 24 pin ATX doesn't take up any more precious space than possible as it is almost touching the ATX female on the mobo. And the 120V receptacle lines up neatly with the back I/O panel, so all the cables go out in the same direction.
After remounting I found out that a component in the PSU blocked the receptacle from going lower, so it sits about 6 mm higher than originally, which interferes with the fan clearance :(
Ah well, these are the things that teach you how to do it better in future iterations. Meanwhile, anyone have a spare 80 mm slim case fan ? :D
Might want to resize the pics man, those are HUGE!
Good idea on the wiring though :)
No kidding. They won't fit on my 2560x1600 monitor. Maybe I should have gotten in on that $1299 Seiki 50" 4k display hot deal last.
Lowered the photo resolutions, thanks.
The next step is to shorten the 24 pin ATX connector by about 6''. That should be interesting. :|
Tested and working. The PSU and CPU fans are whisper quiet. I haven't performed any stress testing yet, but this PSU is rated up to 350w, I believe.
Lessons learned from this project:
When shortening the ATX 24 pin, don't splice all the wires at once and then solder. It's better and easier to splice and solder the shortest wires, then work up, each time checking the orientation. That way your ATX will be perfectly aligned and not "twisted".
Also, ideally it's much better to cut the wires and just solder direct on the PCB pads. But this was my first time and I was hesitant to do that, next time I will! :)
i was wondering about that too. either that, or cut the wires and get the ends fitted with a new one of these
Yes do not splice the wires in the middle, it is far cleaner to solder the wires onto the PCB.
Thanks guys I appreciate it. This was the first time I've done a wire tuck on a PSU, the next iteration I expect it to appear much cleaner.
Anyone know if using copper wires, is it possible to use a 20 AWG instead of 18 on the 24 pin ATX due to the better conductive properties of copper? I really appreciate it! :)
There are some wires on the 24-pin that absolutely need 18AWG as they can go above 6 amps and it would overheat with 20AWG. I can't tell you exactly which wires, cos I never bookmarked the page where I saw it measured. I guess it would also depend on what the motherboard draws, but still I think the ATX24 is not the one you want to mess with.
PCIe cables however, by spec are limited to 4 amps on each +12V line, so theoretically those you can do with 20AWG. (Odd though that Seasonic often uses 16AWG on those PCIe wires - perhaps because they know people use 8->6+6 splitters on them.)
Is that right? Never heard that before - interesting!
I would hazard a guess the +12v wires would have the most current. And I didn't know that PCI-E was limited to 4A either, so thank you!
So, that's just about the diameter right? because i'm going to shorten my cables and resolder them as well, is the length in any way shape or form factoring in?
AWG is about the diameter yes. Making wires shorter is not an issue, provided you solder properly.
