Doghouse Mobius ES
fleks07
Can anyone tell me if this laptop worth it?
I haven't heard of this brand of laptop before, but after checking it out, they seem pretty stable and well built.
I have a decision to make right now, and I would like to hear all the pros and cons.
Here are the specs:
Doghouse Mobius ES
15.6"
i7 4700QM (up to 3.4 GHz)
GTX 770M
16GB Ram
1TB space.
What pros and cons? Does it fit your needs and budget? If so buy it. For anything else you haven't given any information as to what your going to use it for so we can't help you until you give us more information.
More or less gaming, some editing. There isn't much to else to know, I'm basically just asking about the brand in general.
These system are custom built on clevo barebones, high quality hardware. As for the company themselves, I have never heard of them either. If you are interested in clevo systems, XoticPC.com is a certified clevo reseller with excellent customer service. I have dealt with them many times and it was always painless. I definitely recommend you check them out, if you havent already.
I assume it is a Clevo P151SM1.
How much are you paying for this? Briefly looking at there website it seems rather expensive compared to say Xotic or Gentech using the same chassis.
Their 16gb ram configuration also uses 4 SODIMMs (4x4gb) as opposed to 2 SODIMMS (2x8gb).
Leaked Clevo road maps show they are doing a product refreshes starting in February. So depending on how much of a rush you are in you might want to wait.
