Does your Samsung 930B/940B make any noise?
Relentence
I picked up a Samsung Syncmaster 930B and noticed that whenever the brightness is not at 100%, a humming sound comes from the back of the monitor. It's not loud, but can be heard when the room is quiet. I tried the monitor at three different houses to rule out electrical interference and it'll make the sound without even being connected to a PC. Since the monitor was defective, I exchanged it at the store for another one only to discover the exact same problem in the new one.
I was wondering if any fellow 930B/940B owners could momentarily turn down their brightness for me and check for the noise. I tried checking the floor model at the store, but the background noise was too much to hear the sound. Even my monitor sounds silent when in the store.
Thanks for the help.
I have a 940B and it doesn't make any noise, at least not enough to hear it over my cooling fans....
I had 930b for a few days and I didn't really notice any annoying sound. I wasn't listening for it, but during normal use I didn't notice it.
If cooling fans are too loud, it's still easy to test. Set the brightness to around 40, then turn off the computer. The monitor doesn't need an actual signal to generate the noise.
I have very quiet panaflo fans, and can barely hear them, let alone the display, nothing humming on my 940
nothing to do with your monitor but my psp does the very same thing
I have one that I purchased and it does not humm. It should not humm. Get it replaced if you bought it locally. Hopefully you can return it if the retailer lets you. Did you buy an extra warranty? BTW, this truly is an awesome monitor, don't switch it.
