Does wireless component video exist?
Providence
Perhaps someone here knows this more than me...most devices I google for aren't out yet.
My 7900GT has video out, with a three prong cable that attaches to video and two sounds. The only problem is the TV I want to hook it up to is...far away.
Will my video card support a wireless solution? I just want that three prong thing to go into a wireless device, which goes into another wireless device that plugs into my TV using the three prongs (doesn't have DVI on TV).
Is it possible? Does this technology exist?
I see that now...if I'm reading that right, I can use my RGB cables for video and get a converter for my sound jack on the front of the PC and run that into a wireless device...I just wanted to make sure before I bought anything...these things are expensive.
Obviously you will want to read reviews and that sort of stuff before buying as well, but the answer to the actual question is yes.
Whether they are worth buying I have no idea.
