are you wanting the benefits or striping (i.e. RAID0) or just to have a single access point for the entire capacity of both drives? If it's the latter, it's called a spanned volume, and is possible to do. http://technet.microsoft.com/en-us/library/cc772180.aspx But as far as I can tell, you cannot do that with a boot volume.
If it's not a boot volume, you can do it in software, in disk management (span).Yeah, and I am wanting to combine the two different size disks into one. I do not see how this is possible within win 7
Well, I used my 3Tb and my 1.5 TB and it worked. Shows as one big drive.
But what happens is I reformat my machine? Will windows see it after I am done installing?
Or will I loose that spanned volume of data?
