nicksinif said:lets say my upload limit is 30k/s and my download is 300k/s. if i am using 25k upload, will that affect the download speed of 300? or are they unrelated?
Uh, what? Last I looked, coax doesn't have 4 wires.Stellar said:Theoretically speaking they shouldn't interfere with one another... they are physically separate (2 send wires, 2 receive wires),
movax said:Uh, what? Last I looked, coax doesn't have 4 wires.
@OP: Setup QoS to limit upload for P2P and other stuff to around 90, 85% of your max upload speed. That way, ACK packets always have a chance to make it out relative unhindered. You notice a slowdown because you've saturated your upstream, slowing down the ACKs responding to the SYNs.
Stellar said:Theoretically speaking they shouldn't interfere with one another... they are physically separate (2 send wires, 2 receive wires), but the fact that there is software overhead involved at both ends above the network layer when you have multiple connections adds a bit to latency both ways.
The original poster never said what kind of connection he is talking about. This could be DSL, or cable (could be something else but those are my best guesses)Stellar said:Theoretically speaking they shouldn't interfere with one another... they are physically separate (2 send wires, 2 receive wires), but the fact that there is software overhead involved at both ends above the network layer when you have multiple connections adds a bit to latency both ways.
second post
Who said anything about coax?
Your a bit off, TCP will send multiple packets before it waits on an ACK, thats dynamicly adjusted up and down based on how well things repsond, its known as the sliding window.da sponge said:False.
The reason your downloads slow down when you're saturating your upstream bandwidth is that for each packet you receive you need to send an ACK back before you get sent another packet. If your upload is saturated, that ACK will get delayed/discarded. You won't get the next packet until the sender receives that ACK.
I'm no TCP expert, but I think the general idea is correct.
Stellar said:"False"
You just restated what I stated. (i.e. "overhead" both ways, multiple connections), only you were more specific.
TCP uses ACK, UDP does not. I believe BT does use TCP though. Thing is an ACK packet is tiny, and pretty insignificant compared to uploading data (like when your seeding to others). I read the rest of your post, but I wanted to make sure some one didn't get confused by this statement.goodcooper said:can't have packs without acks... it is as simple as that...
i guess i can't say that this is wrong, just that it makes no difference, has nothing to do with the OP's request...Ur_Mom said:A T1, which is syncronious, can do both at the same time.
DSL/Cable, Dial up are asyncronious. They can only send or recieve. They can only do one.
For the most part (half/full duplex).
This may be old or even wrong, as I haven't looked into it for a while.
Xipher said:TCP uses ACK, UDP does not. I believe BT does use TCP though. Thing is an ACK packet is tiny, and pretty insignificant compared to uploading data (like when your seeding to others). I read the rest of your post, but I wanted to make sure some one didn't get confused by this statement.
