does underclocking save power/fan life?
Santasballz
hi, due to my business, i always have to leave my computer idle
my graphics card is: ATI AWI x800xt
default core 500, mem 500
i was wondering...would i save power, and the fan's life (slowing it down) if i were to underclock it? are there any DISADVANTAGES in doing this? will it harm my card? void warranty?
also, how low can i make the frequency so that i still can use computer for word processing, webbuilding, email answering
thanks
first, why do you have a xl800xt for your business machine that stays on all the time? it's a waste.
second....underclocking a graphics card will only save you little power as the core is sitting idle anyways. the xl800xt is probably idling at 30W (i am guessing here). and underclocking the core/memory clock will be almost linear in power reduction, meaning a 10% core downclock will yield about 10% idle power savings ....which is only 3W. Now reducing voltage will have a squared effect in power as Power is proportional to V^2. So you can reduce voltage and underclock at the same time and will probably cut the idle power in half....which is only 10-15W saving in power.
to underclock core/mem, use powerstrip.
underclocking voltage will require volt mod, which would void your waranty.
So my suggestion is to use powerstrip whenver you don't game on the card
Yeh it should make a difference but i dont know how big
Should make a difference in temps as well
PS to the mods isn't this General video card topic since it isnt ATI specific :eek:
Indeed it is... a Radeon 9250 64mb would be the trick.
tshen_83 said:
first, why do you have a x800xt AIW for your business machine that stays on all the time? it's a waste.
fixed for you sir ;)
and yeah get a cheapy tv tuner and a low end vid card, you dont need that for an office pc
soulsaver
